Chgment autoradio - Récupération des infos: température, etc
Re: Chgment autoradio - Récupération des infos: température, etc
bibliothèque à installer
https://github.com/Seeed-Studio/CAN_BUS_Shield
https://www.arduino.cc/en/Reference/SPI
code à compiler
http://vinzzz3410.synology.me/tuscani/genlcd_lib.rar
Code : Tout sélectionner
Infotainment (Hyundai Genesis Coupe) Wake Up LCD Screen
(c)2014 Wesley Treihaft
Thanks to Dreadie for the command.
#include <mcp_can.h>
#include <SPI.h>
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 9;
MCP_CAN CAN(SPI_CS_PIN); // Set CS pin
unsigned char stmp[8] = {67, 02, 0, 0, 0, 0, 255, 255}; // Wake Up Command Data (Dec)
unsigned char stlcd[8] = {16, 84, 117, 115, 99, 97, 110, 105}; // write top lcd Tuscani (Dec)
void setup()
  Serial.begin(115200);
  if(CAN.begin(CAN_100KBPS) ==CAN_OK) Serial.print("can init ok!!\r\n"); // Init CAN Bus, Baudrate: 100k
  else Serial.print("Can init fail!!\r\n");
  delay(2000); //Delay to wait for the hardware to stabilize
  CAN.sendMsgBuf(1088, 0, 8, stmp); // Send Wake Command Once
  delay(2000);
  CAN.sendMsgBuf(1152, 0, 8, stlcd);
void loop()
// CAN.sendMsgBuf(1088, 0, 8, stmp); // Send Wake Command Repeat
// delay(100); // Repeat Delay
// Wake Up Hex Command: 0x440, 0x43, 0x02, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF
je rajoute aussi se code qui permet de sniffer le can bus low de la gen, si le code fournie ne fonctionne pas il faudra faire un dump avec et sans autoradio pour trouver la commande magic ;)
//This Arduino UNO Sketch requires the Seeed CAN-BUS Shield Libraries
//https://github.com/yexiaobo-seeedstudio/CAN_BUS_Shield
#include <SPI.h>
#define INT32U unsigned char
INT32U canId = 0x000;
unsigned char len = 0;
unsigned char buf[8];
char str[20];
void setup()
    Serial.begin(38400);
START_INIT:
    if(CAN_OK == CAN.begin(CAN_100KBPS))
        Serial.println("CAN BUS Shield init ok!");
    else
        Serial.println("CAN BUS Shield init fail");
        Serial.println("Init CAN BUS Shield again");
        delay(100);
        goto START_INIT;
void loop()
    if(CAN_MSGAVAIL == CAN.checkReceive())
        CAN.readMsgBuf(&len, buf);
        canId = CAN.getCanId();
        Serial.print("<");Serial.print(canId);Serial.print(",");
        for(int i = 0; i<len; i++)
            Serial.print(buf[i]);Serial.print(",");
        Serial.print(">");
        Serial.println();
attention scam je te prépares le super sniffer ;)
p*!@i# c chinois pour moi :ptdr: :ptdr: :ptdr:
donocast
Marque : HYUNDAI
Motorisation : 3.8 boite auto
Message par donocast »
Tu t'éclates vinzz34 :D . Un de mes potes a des arduino qui trainent. Je vais voir pour en emprunter un. Par contre si on ajoute un régulateur de tension, il faut prévoir de quoi le refroidir (ça chauffe ces bêtes).
si ton câblage marche tu me diras on fera une version final pdf (propre et tout). Il faudrait voir pour ajouter un boitier plastique. On doit pouvoir en imprimer en 3D avec quelques dimensions
donocast a écrit :Tu t'éclates vinzz34 :D . Un de mes potes a des arduino qui trainent. Je vais voir pour en emprunter un. Par contre si on ajoute un régulateur de tension, il faut prévoir de quoi le refroidir (ça chauffe ces bêtes).
j'ai malheureusement pas de gen pour faire mumuse avec le can bus, la gk a un vieux bus pourris, pour le régulateur j'ai fait commandé des clones chinois a scam histoire de faire des économies... il utilisera l'alimentation de l'ordinateur dans un premier temps, quand scam aura tout reçu et câblé on regardera pour une version compact et propre déjà si on arrive a bypass l'ancien autoradio ça serait cool , le reste c'est du pure bonus ;)
pour que je m'éclate il faudrait m'envoyer un afficheur de gen et un autoradio d'origine :D
tilou
Modèle : genesis
Motorisation : 2 litres
Année : 2012
Message par tilou »
Alors pour l'autoradio aucun souci pour sa. Par contre le module écran bleu c est mort si on l'enlève sa empêche le mouvement des vitres quand on ouvre les portes et sa deconne le verrouillage des portières pour fermer la voiture..
Octane
Motorisation : 3.8 boite meca
Message par Octane »
J'y comprend rien à vos histoire de CAN-BUS lignes de code
... mais si y a possibilité de gagner 100Cc je suis preneur :lol2:
tilou a écrit :Alors pour l'autoradio aucun souci pour sa. Par contre le module écran bleu c est mort si on l'enlève sa empêche le mouvement des vitres quand on ouvre les portes et sa deconne le verrouillage des portières pour fermer la voiture..
sérieux :O_O:
tilou
Modèle : genesis
Année : 2012
Message par tilou »
Oui sinon je t'aurais proposer de t'envoyer les deux !
mon dyndns ayant changer voici le nouveau lien , ps je n'arrives pas à modifier mon message :wut:
http://cbr125.myphotos.cc/tuscani/genlcd_lib.rar
fb78
Motorisation : 2.0L - Turbo - 214ch
Année : 2012
Message par fb78 »
Salut vinzzz34,
Je suis ce post avec INTÉRÊT et j'ai cherché sur le net des infos et des progs. :failnotice:
Et j'ai trouvé comme toi le super sniffer de bus CAN. :)
J'essaie de mon coté de développer en VB sur un PICAXE 20x2 et un Arduino CAN-shield UNO un prog pour gérer l'afficheur haut devenu "muet" suite au changement de l'autoradio mais c'est pas facile :flipe:
As-tu avancé sur le chmilblig ? Tiens-moi au courant du projet. Merci :inlove:
Bonjour fb78,
on a fait fonctionné le sniffer avec SCAM mais par téléphone sans accès distant sur l'ordinateur c'est impossible de travailler efficacement,
il faudrait sniffé le can bus avec l'auto radio d'origine et repérer les ID relatif a l'écriture sur l'écran et la température .
Si tu as un sniffer fonctionnel tu pourrais surement nous aider.
Si quelqu'un pouvait m'envoyer un lcd et un autoradio d'origine, je penses que je pourrais m'en sortir ...
Ou a la limite l'adaptateur pionner qui fonctionne.
Duncan
Message par Duncan »
Si tu avais un accès à distance sur un pc portable par exemple, ça pourrait le faire ?
Duncan a écrit :Si tu avais un accès à distance sur un pc portable par exemple, ça pourrait le faire ?
oui je serais déjà un peu plus à l'aise ;)
Scam n'a malheureusement pas le net dans son garage :ohno:
Pour l'heure , il faut que l'auto radio d'origine soit en place et scruté tout les changements ensuite un module RTC arduino fera le boulot pour afficher l'heure.
Pour la température il faudrait chauffer le bouclier avant avec un sèche cheveux.
Et au final pour afficher des trucs sur le lcd il faut que l'autoradio soit actif et affiche le nom de chanson etc
En bref il faut un sniffer actif et faire varié les informations qu'on souhaite récupérer
sachant que je ne peux pas modifier mon post une petite correction
le can id doit être de type int et non char
#include <SPI.h>
#define INT32U unsigned int
char str[20];
void setup()
START_INIT:
    else
        delay(100);
        goto START_INIT;
void loop()
        Serial.print(">");
        Serial.println();
